| headlight mounts I believe the headlight mounting rings are those of the vauxhall viva hc ,can any one confirm this ,or even send a photo of the item.
a second question about the wiring looms,The front fan acessory loom has the hand brake warning cable (yellow and White) it also has the tail brake terminal y/w with a micro connector,where does it go is it straight to the fuse box/relay loom somhow? |
