| This is what I had done for my RF, which of course never came, thus the motor is going in the Lola. I think it capable of extended track work.
342 inch SB Ford
AFR 185 heads, custom CNC porting job
11.5:1 Compression, Custom forged pistons
Forged crank, now zero balanced
Forged Eagle H beam rods
DDS main support and windage tray with crank scraper
Comp Cam cam Specs:
0.676" lift IN, 0.673" lift EX
Duration at 0.020 287 IN 295EX
Timing @ 0.050" IN Open 18 BTDC Close BTDC 58
Timing @ 0.050" EX Open 61 BTDC Close BTDC 21
110 Lobe separation
Comp Cam Valve springs and titanium retainers, 600lb open, 260lb seat
Jesel Comp Series Shaft rockers
Jesel Pushrods
Jesel Keyway solid roller lifters
Ferrea Hollow Stem Intake and Exhaust Valves, 2.02/1.60
Total Seal rings
ARP 1/2" head studs, ARP hardware throughout motor
ACL 3/4 grove race main bearings
Now I fear after having a year of SCCA wheel to wheel racing and track work under my belt, I think the engine is too much. So, I might be detuning it for the Lola. I think around 350-400 tops would be great for a 2000lb, or less, Lola track toy or a GT40 weighing a little more. I went for high revving power and little torque, or as little as it'd make, so as to fit with the Audi/Getrag steep transaxle. If you are using a ZF you might not want that much high end power as the ZFs are lazy, or at least the ones I've driven in Panteras, fairly tall ratios. You might need the torque and mid-range power, especially if you plan your RF to be on the heavy side.
R
Ron
