Old 05-15-06, 07:46 PM   #143 (permalink)
aladinsane's Avatar
aladinsane
GT40: Tornado
........If it's flat, are you planning to dome it and if so, how?.....
Mark,
Here's my trick to doming the rear window:
Close the rear clip and let the motor run and heat up the rear window. The warm motor will make the plastic droop in about 20 min. Open the rear clip and with a soft towel push lightly from the inside to get the desired dome. I then wedge a couple towels between the window and rear clip to maintain the dome while it cools. Let it cool down completely (the cooler the better) before removing the towels. It should now retain it's dome shape though many heat cycles. Hope that helps
Tornado TS40, Dart Alum 351\427, 8 Stack EFI
G50\52 w\cooler, cable side shift, Halibrand KO, Hoosiers
aladinsane is offline   Reply With Quote
