| Thanks Peter and Malc
As you can see from the picture of the knuckle whatever was previously attached also had big holes, so I guess this is not something out of the ordinary. The bearing assembly is, I believe, now generic - you get the toothed wheel whether you need it or not.
Because the bearing is located radially, which is the important bit, I think it will be OK just bolted up with normal bolts, but I was hoping someone could confirm the usual arrangement, (and confirm that what was previously attached had large holes as well)
All the best |
