| You may want to consider Prothane (P/N PTP-6-503-BL) mounts for 67 Mustangs. Most motor mounts for early Mustangs are now made in China and are of questionable quality (I have broken two such mounts in my V8 Capri). Especially true if you are buying them from AutoZone et al.
These are available from Summit (and in black). As you can see in the photo, failure of the urethane will not result in a motor mount separation. Under $100 USD.
Even though this is slightly wider than the OEM mount, it appears that it would work in this application (judging from Ross' photo)
Al |
