| As I understand it, it all depends on drive line loss ie: gearbox, tyre size/pressure etc. which is different for every car. As I understand it, about -15-20% is the ball park. If you talk to three different dyno operators, you usually get three different answers - bit like Economics graduates. My guestimate would be that yours is putting out in the region of 430-450hp at the fly.
I always use the same dyno and he uses the same settings every time, so at least I can compare apples with apples. If driving the car gives you sweatty palms, then you know the power is sufficient.
You can always do what Rolls Royce used to do - just quote the power as "ample"!
Greg
__________________ Inside every older person is a younger person wondering what the hell happened. |
