Old 06-08-06, 06:47 AM   #23 (permalink)
delaneyp's Avatar
delaneyp
Peter D
GT40: DRB #27
A post forwarded on by a mate of mine here in Oz - Chris C :
Canuk 40 may have saved a lot of time and money using what is fitted to RF054.See attached pics which were posted some 2 years ago on this site. Only 1 member ever commented. Manifold is a DCO&E (Sydney Aust.) typically used on their superb 8 barrel fuel injection system. Was the standard 8 barrel system on a RF. The manifold incorporates a vacuum chamber with 2 ports - 1 for the ECU and the other for power brakes etc. A little Ozzie ingenuity with cast Weber adaptors-again off the shelf items- has the Webers sitting correctly as per original and no one can really tell the difference at first glance. I prefer a perspex back fire plate so the Webers are still quite visible through the rear window. The manifold - adaptors- studs-gaskets etc cost Aus.$900. A lot cheaper and superior to some of the Weber manifolds that are currently available.
Cheers.
Name:	DSCF0594 (Small).JPG
ID:	13983  Click image for larger version
Name:	DSCF0593 (Small).JPG
ID:	13984  Click image for larger version
Name:	DSCF0585 (Small).JPG
DRB (GT40 Australia) #27
331 Windsor / GD-50
8-Stack EFI / Autronic
Dark Metallic Blue Pearl
delaneyp is offline   Reply With Quote
