Old 06-19-06, 04:21 PM   #1 (permalink)
Kalun_D's Avatar
Kalun_D
5 Tenths
GT40: Scratch build
Rep Power: 10 Kalun_D will become famous soon enough
Cam Sync Sensor Wiring
Accel Gen7 ECU
Fast Edist DIS
Using a cam sync sensor from a Ford Exploder, believe it's a 1996. The one that goes in the place of the distributor.
It's a hall effect (??) sensor with 3 terminals. The local dealer isn't too helpful and won't let me look at the manuals. Need to figure out what wire goes to which terminal.
from the ECU and DIS there's a cam signal wire and a signal return (ground). Although the ECU and DIS wire diagrams don't show a 3rd wire for the cam sensor I'm assuming it's a 5v reference which the tps and map sensor both have.
Kalun_D is offline   Reply With Quote
