Thread: Mercedes Power?
Old 06-23-06, 03:12 AM   #9 (permalink)
CliffBeer's Avatar
CliffBeer
CURRENTLY BANNED
GT40: CAV mono
Rep Power: 0 CliffBeer can only hope to improve
Originally Posted by jimbo
I do not think you would get any more power with Webers than you could get by remapping the Bosch EFI which is a very sophisticated system. Mercedes engines are complex and put out a lot of power for their weight and displacement. There are probably AMG bits for it that would up the output. Rather than try to emulate the Ford engine (Webers etc) you would be better off making it the hottest MB engine you could, which means working inside their technology.
Pagani uses Mercedes engines, don't they? and they go pretty fast.
And if you really want to get crazy, I have a spare 1971 6.3 MB M100 engine sitting around with nothing to do. Karl Middelhauve built one of those to over 600hp and ferocious torque a year or two ago.
Hi, yes, you may be right that sticking with the EFI and remapping the ignition is likely to produce equivalent hp to the webers. Plus, installation of webers will absolutely require reground cams and who knows what the best ramp/profile would be for those. Was really only thinking of the webers for visual appearances sake. Will need to think on it a bit more!
The 6.3 is certainly an impressive beast! Now that would be the engine to put some webers on! Thanks!
CliffBeer is offline   Reply With Quote
