Originally Posted by Russ Noble The most obvious cause of rear wheel steer (bump steer at the back, Pete) is placement of the lower radius rod forward pickup point too high on the chassis. You can't run a high forward pickup point with a reverse lower "A" arm.
Cheers,
Russ |
How high is high? Or, how much above the roll center is deemed "high"?
