Update on Jims RF Body Hinges Sometimes better late than never really does apply. As an update to the above post I finally got around to fitting the new hinges to my front and rear clips and have a couple of comments.
Firstly the installation was a snap, the only items I needed to address was reaming out the bolt holes that the frame attachment bolts went through, and this was only slightly. The reason was that I used the same bolts that were supplied by RF for this purpose. Secondly I had to adjust the hight of the arm attaching to the clip by about 1/2 inch to bring the at rest hight of the clip back into alignment. I think total time spent on installation was less than an hour.
The result is great, removing the clip now takes only a moment and adjusting the clip side to side only requires undoing two screws, lifting the clamps and pushing the clip were you want it. Without a doubt this change makes working on the car easy. You don't realize how much c*&%^ you went through with the clips when you needed to work on the car untill you do this modification. For what it's worth every RF owner should consider it.
Peter
PS. Jim if you read this post yes I am kissing up for the door hinges.
__________________ Roaring Forties #80
306CUI, SBF,8 Stack Injection
Motec M800 ECU
Audi 5N with 3.22 Ring and pinion
17 inch Vintage Wheels
Florida Plate # GT40 MK1 |
