Old 08-14-06, 12:19 AM   #18 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 21 jac mac has much to be proud ofjac mac has much to be proud of
Wink I knew this would happen!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Originally Posted by Ron Earp
Jac Mac,
That thing is a POS. (WONT ARGUE WITH THAT)
If I mount the two piece cam the outer ring will not spin - it can't. The inner, when the cam bolt is tight, will hold down one side of the thing and trap it against the cam gear.( & now you have re-read post#3)
If I put a washer under the inner piece, to space it up like 0.100" (optimal would be less, just mock up here) then it will spin, but it seems like a flimsy POS.( DITTO- but the washer needs to be thinner)
I think I'll use the early model one piece and tap that hole I drilled, and afix it that way. I think I'd feel better about all that. ( Good Idea)
Ron
Race Cars are just sooo much fun are they not!
Jac Mac
