Old 08-29-06, 12:37 PM   #1 (permalink)
HUW PEPLOW's Avatar
HUW PEPLOW
GT40: rf40 118
Rep Power: 4 HUW PEPLOW will become famous soon enough
drive shafts and cv joints
just assembling them and the manual says very little.
I assume (usually not a wise thing) that the adaptor plate fits on the gear box side.
the bolts then need to be seated below the grove in the plate to allow the cv joint to sit within . there were no bolts supplied so any idea on the type used and their dimensions, they are m10 but all the ones I can find with allen key type heads are too large to fit the pre driled holes except for those with the cv joint kit ,but they are to high in their seating and the thread is too long!! Might have to use my 4and1/2 inch high speed lathe
the cv joints themselves have one flat side and one lipped side should one side face a particular way??
finally has any one used the engine mounts from summit racing (pbt-6-503-bl)
as the look like a replace ment .Mine were so deformed they put the gear box 1/4 inch out and it was hitting the lt rear chasis even with a little hole slotting .
must learn to post some pictures to let you all see #118s progress,nearly ready for paint
HUW PEPLOW is offline   Reply With Quote
