Paul Thompson 'Hooligan'
Hi all -
Here's a puzzle for you, I am looking at an oil leak issue on a GTD at the moment and whilst talking to the owner, he mentioned a 'heavy vibration' throughout the rev range, since having the flywheel lightened recently.
The original Essex flywheel was shot, so a replacement was sourced and lightened by someone he describes as very knowledgeable who also balanced it (with clutch) to match the older, already lightened, but defective flywheel.
Now I have driven a car with the flywheel in the 'wrong' position and it did indeed vibrate like hell and he said the motor was silky smooth prior to this work being completed.
SO, does anyone know the correct position for the flywheel to the crank??
I was under the impression that they are indexed by a slightly offset mounting hole, but he also mentioned that the 'person' who had removed the flywheel and refit (NOT the balancer/lightener) said something about 'filing one of the holes'.... (hmmmm - but was it the right one?....)
If I remove the thin inspection cover from in front of the adapter plate below the rear of the sump, I can view the rear of the cast flywheel.
So, I figure if I turn the motor so that the center of the counter-weight cast into the flywheel, is pointing directly down, eg '6:00 o-clock', I could then count how many degrees I have to turn the crank clockwise for TDC no. 1 cylinder... This, compared to another standard GTD should indicate whether the flywheel is one or more lugs (each 60 degrees) out - or am I missing something...?
Motor is standard 302 (2-bolt) with 15426378 firing order, should it make a difference which I cannot see it doing so.
Any ideas to confirm would be appreciated as the owner has lost confidence in the previous 'mechanic'....
I also think that I should be able to tell by looking at the damper position on the front of the crank, but am not sure, hence the question.
