| Re: Engines' skewed a bit... Quote: |
Originally Posted by Fatal Attraction Ray,
When I installed my TWM manifold, I had to do a minor "adjustment" on the fiberglass at the rear of the hole, in order to accomodate the fuel rail crossover block. I sanded the radiused edge back from the underside, so not to get into the paint, then touched up the black underneath.
I was thinking that your turkey pan sat underneath the clip, not through it.
Too bad that your pan isn't just a tad more vertical toward the back.
Bill | I've done a bit of that adjustment (sanding). Looking at the pan directly from the rear, though shows at least an inch discrepancy. I may just raise the left side a bit with a wedge or washers. I'm just afraid I'd twist things and compromise the integrity of the engine mounting.
__________________ Ray
GT40 CAV Mono29
Cobra SPF #1052
MB CL600 V12
'67 Austin Mini Cooper S
MB E350 4matic (commuter)
Looking for a Cessna Aerobat |
