| Fuel Regulator Question Sorry for what may be a silly question but I need to check that I have set my fuel pressure regulator correctly. The Weber carb I have on my car requires a fuel pressuree of 5.5 psi (6 psi maximum). When I installed it I used the gauge supplied with the filter king regulator. I adjusted the pressure when the engine was on, running at idle. Is that correct? or should this be set when the engine is off?. Does the engine have to be hot or would this make no difference. Any advice on the correct proceedure would be most appreciated.
SImon |
