Re: Rear suspension bump steer This is a wonderful discussion! Who can resist? There is a great road near my house that has a long straightaway that happens to be the only passing area for about 9 miles of twistys, at the end of the staight is a dip that causes the car to unload just as you are braking hard for a sweeping right hander.
The first time I had my CAV out(after extensive shakedown and engine break in) I blasted by 5 ordinary citizens at about warp 6, pulled back into the right lane and started braking for the turn just as I hit the dip. The rear suspension unloaded and when the car came back down it was all over the road! Must have been very entertaining for the masses following me, as I am sure they would like to see me get my comeuppance!.
Needless to say my interest in bump steer began to peak.
I found several issues with the stock CAV rear set up. I saw Bob Childresse's excellent build pages on his CAV and contacted Ian(Canuck 40) and purchased one of his lower control arm kits(spherical bearing on the inner) toe adjustment possible without shims and some bushings that allowed the upright to be pushed further back in the wheel opening. I found that at full droop the sway bar links were binding on the lower control arms and had to relieve the clevis' to allow more movement, I removed the spring spacers from the shocks(I did not want to redesign the entire car), tilted the uprights back at the top and headed for my favorite real world bump steer test site.
The car was transformed and is now much more predictable and nuetral handling.
I too am a closet engineer but sometimes you can just look at something and know if it will work or not, but the best thing(for me) is to experiment a little and drive it.
My goal with this car is to have it brake and handle like my Euro Swift Formula Ford, ride better than my SLK 350, and be scary fast and utterly reliable. (beside the obvious looks and sound of the thing).
I hope this helps somebody with this subject.
Dave
__________________ Cav GT 40, 02 Lightning, 65 R model clone, 66 Al Craft Indy Car, 03 SL 500, 03 Triumph Bonneville. |
