Old 10-31-06, 07:14 AM   #8 (permalink)
nota2266's Avatar
nota2266
GT40: Kurrajong, Australia
Re: Fuel Regulator Question
Simon,
Dont take your gaige for granted that it is accurate.
Connect a long piece of clear plastic tubing to the pump and then hook it up to the ceiling or something else to hold it near vertical. the open end of the tube will need to be about 10 feet above the pump, turn the pump on and measure the height of the fuel level(in the tube). the height in feet x 0.434=psi You can mount the tube on a piece of wood with graduations marked it is easier
Trevor Booth,
Finished assembling a pile of bits incl, mono, 302W on IDF's,ZF, 15" pin drive BRM.
nota2266 is offline   Reply With Quote
