| Re: Fuel Regulator Question Cheers Ian
That I did not know about. I will go and check to make sure the HT leads are spaced correctly. I was going get the rotor arm from our local Land Rover dealer on the Isle of Wight, but they don't keep rotor arms in stock!!!, can you believe it!. In the end I got one from a TVR dealer who had an orginal Lucus part in stock for my Chimera engine.
BTW, hows is the Dax going? Have you rectified the gearbox and driveshaft issues you had?. I know that I had to do some serious leak plugging on my Renualt 21 gearbox and driveshaf adapters!. No leaks now though so it was worth it.
Simon
