| Re: Coolant Pipe Routing Hey Paul
I'm planning on using a Davies Craig EWP aswell, I've fitted my pump up front
and blanked off the orginal water pump housing. I'm wondering how your
car copes inregards to engine temp when your at a track day?
Did you remove the thermostate? and are you using the DC pump controller
or just running the pump flat out with a thermostate??
Oh and I ran a bleed pipe from the top of the radiator to a high mounted header tank which runs through the centre tunnel.
__________________ What! another DRB GT40...
