Re: Front suspension settings and upgrades Hi Ross
Yeah the list of mods look quite long but the only change to the geometry was to increase Ackerman, the rest of the settings should be the same as std RF. Hopefully this change will work for me, will have to wait and see.
Hi Chris
If your brakes are getting that hot, I would try a set of DS3000’s first. You will be impressed, I’ll even put money on it : )
I have tried ‘Hawk blues’, ‘EBC yellows’ and ‘DS3000’s’ ( not on a GT40 though ) and the 3000’s are heads and shoulders above the rest in my opinion.
Do you check your tyre pressures after each run ??
I have found that if the rears gain 1-2 psi over optimum it becomes taily.
Again that’s what I’ve found anyway.
Clayton |
