Old 12-03-06, 02:03 PM   #6 (permalink)
StanJ
Sponsoring Vendor
Rep Power: 4 StanJ is on a distinguished road
Re: Carby question ?
Originally Posted by flatchat
-- just hope I can get a carby manifold for the LS6
If you’re looking for a dual plane style manifold for your LS motor, Edelbrock has one available under part number 7118. They also have a taller, single plane “Victor Jr.” style manifold available under part number #2908. Both of these are available with special electronics that allow the stock coil pack ignition to function in carbureted applications.
If hood clearance is an issue AND for some reason you don’t want to utilize a multi-coil crank trigger style ignition system, consider this one:
GM Performance Parts | Find a Performance Part
along with these special front cover/distributor drive/water pump components available from Wegner Automotive Research Wegner Automotive - Product Catalog
StanJ is offline   Reply With Quote
