| Re: Tire sizes Dean, this is the stcok front tyre size ...as you see its pretty close to 25inches....so as long as you stay in the same ballpark you will be fine.
Stock Tire - 205/60R15 >Search Tires
Section Width: 8.07 in 205 mm
Rim Diameter: 15 in 381 mm
Rim Width Range: 5.5 - 8 in
Overall Diameter: 24.68 in 626.87 mm
Sidewall Height: 4.84 in 122.93 mm
Radius: 12.34 in 313.43 mm
Circumference: 77.53 in 1969.2 mm
Revs per Mile: 842.7
Hope this helps you.....
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF www.RACECARREPLICAS.COM www.superlitecars.com |
