| Grease leaking from the hub drive boot After a lengthy run today, I noticed what appears to be bearing grease seeping from under the driveshaft boot on my right rear upright. The clamp is not adjustable so I was reluctant to peek. Has anyone repacked the rear wheel bearing and can tell me if there is a wheel bearing seal on both sides? If so, do you have the size so I can order it and any tips on replacing it? The seepage isn't too bad so I don't want to pull it apart until I have the kit to complete the job.
__________________ Regards,
VEEK
CAV #04
Florida |
