| Re: How can I get dash to fit Jay
I had a similar problem...I tried it out in sunlight but it wasn't enough heat so I got a couple of those red heat lamps and hung them above while clamping the dash down and it worked well. Don't get too close with this method, and be patient and it will work. Also if you clamp try to spread the force so as not to create more deformation than you started with such as rob suggested with a plank.
Good Luck
Phil |
