| Re: R21 Gearbox cooler Here's a couple of shots from the top. I tried to keep all the hoses short so that there would be less weight on the fitting at the pump. The pump housing is a plastic composite material and so you need to be careful with the threaded ports.
You can see that the top of the gearbox has two return lines. One on the right returns right at the top of the ring gear. The other returns right onto 5th gear. |
