Old 01-01-07, 09:40 AM   #15 (permalink)
dalesince59
GT40: gt40 modified fiberfab avenger
Rep Power: 3 dalesince59 is on a distinguished road
Post Re: BMW V12 E32 Engine Dimensions
this is a stock compression motor,premium pump gas. inductiion system is tube intake manifolds with six blow thru, turbo modified deloroto dhla 40 mm side draft carbs, 1/2'' aluminum fuel lines, elect. fuel injection pump with a by pass return system using a mallory boost referenced fuel regulator. i am in process with this project [ along with a dozen others] . i have no immediate plans to turbo charge the motor but this is a perfect candidate to do it on and i already have the fuel and ignition system in place should the need for some boost arise.
dale
dalesince59 is offline   Reply With Quote
