| Re: Brrrrrrrrr....cold in my CAV.... Quick update here gents - checked the lever arm on the solenoid valve and everything it attached correctly there (the lever arm had not dropped off the actuator), however, one of the vacuum lines (the rearward one) wasn't attached to the item directly next to it (the dashpot?).
Anybody know what/where the rearward vacuum line is supposed to go? I don't see an unattached vacuum line hanging around in the area which would obvoiusly be it.
Thanks in advance! |
