| Re: S2000 start switch After being up most of the night at the hospital(on call). I went out to the local Honda bone yard. They had a 2000 that had been picked over and I was able to get the 5 pin connector. I also had found the original wiring diagram for Honda, so was able to tell which of the two connectors was the right one(one had the three wires, one has all five slots taken up). Those guys were reluctant to cut any of the harness except the whole dash was gone and the harness had been butalized anyway. So I got the connector and now it is on to hooking it up. What you guys have posted goes exactly with what I have found. The connector fits the three wires to the left side of the switch when in the upright position. Had I found the info you guys have posted prior to buying the switch, I would have probably bought one of the prewired buttons, with the exception they aren't chromed(plastic). Cost is about the same no matter which way you go with the above info.
__________________ DRB#5
351W/408 DIS TWM F. I. 930 Porsche LSD |
