Old 01-20-07, 09:04 PM   #2 (permalink)
easta's Avatar
easta
GT40: Roaring Forties 94
Rep Power: 4 easta is on a distinguished road
Re: gear change and box issues
Hi Huw,
You are correct reverse is to the left and forward. A couple of areas you may need to check. Firstly oil: RF use Catrol Mutli trax for the transaxle. The rod mechanism at the rear join enables to postion across the flat\spine in three possible positions this may assit in getting the throw far enough out to select reverse. Also the lock nut on the small rod joining the selector rod out of the gear to the main change rod if to long when selecting reverse hits the main rod preventing reverse from being selected. Also worth checking you are getting clearance around the panelling at the gear change lever, with mine I had to file a fair bit out of the hole to get sufficient clearance to select all gears. Hope the above gives you some clues to your selection issues.
Andrew
RF GT40
Chassis #94
302W / 6 Speed LSD
easta is offline   Reply With Quote
