| Re: Rear Bulkhead Window Gents.
it was designed to go on the cockpit side and create a pinch for the carpet on the firewall and then give you a nice finished trim around the window...I know some of you are not using carpet....so its your call in that case.
Make sure to use the correct length nyloc nuts and ss bolts/cap heads , if the shank is too long it will hit the rollbar and create a fitment issue...
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF www.RACECARREPLICAS.COM www.superlitecars.com |
