Originally Posted by jonathans On the pedals I ended up mounting mine at a little bit of an angle to clear the control arm mount. I don't think the angle will be noticeable when you drive. It is certainly the easiest solution. |
Don't know which Tilton masters Fran supplies, but you can also get 'Shorty' versions of if the standard Tilton's were used. I the standard version are the 74 series and the 75 (or remote only 76). I used the shorties to replace some on another car and worked just fine, the only issues is you have to use the smaller reservoir, but if remote mount are used not an issues. Body length goes down from around 5.5" to 3.25"
[edit-added]
Found the links to the dimensions of both
http://www.tiltonracing.com/pdfs/83.pdf http://www.tiltonracing.com/pdfs/84.pdf
Sandy
