| Re: Rcr-p How Sooooooooooon?????? Howard,
everything you have listed is almost exactly the way the car is speced as a track car...
There are vents infront of the rear wheels that are deeper than they appear, your IC will function well there...
Alternatively we have planned on having a sheetmetal mesh replacing the rear window to alleviate engine bay heat on the track version..so you could mount it there too.
The roof scoop has a split allowing air into the cockpit and also redirecting to the engine bay ...the position of the scoop aft of the windshield trailing edge is not a super high pressure area due to the deflection of air but there is enough flow to still be useful.
The fuel tanks are mounted behind the seats..ala Daytona Proto.....you could mount a smaller 10 gal. unit there very easily.
All of the RCR-P cars will have a front roll hoop as standard...
Standard wheel package is still Corvette C5 due to the availability and lower cost options.
Bolt on 5 x 4.75 wheels as standard....
Billet uprights following on from the first transverse P car shown at Carlisle in 06.
The new chassis and body package will support upto 17 inch wide rear and 14 inch front rubber should someone desire to do such a thing.
The body does not hinge....it is lift off only....
The rear window will hinge to allow easy access for general checks but the rear clip must be lifted off for any major work...
Hope this helps.....the rest is up to your own imagination.....so keep the ideas coming.
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF www.RACECARREPLICAS.COM www.superlitecars.com |
