air filter
I have a roush 342 installed in 118 and with their standard 'oval' filter cannot shut the rear clip as the engine is sitting too high by about 1 inch. Can any one suggest a suitable air filter to fit the holley carb that would give suitable clearance but maintain air flow,
On 'American hot rod andWrecks To Riches have seen air filters that both take air from above and the sides therefore are considerably smaller,Any ideas or anyone out there with a similar problem but solved it
For the Holley on P1116 we made a rectangular base that approxamated the shape of the Weber tray and a matching lid. We then found a K&N filter about 1.5" tall that was a large circular shape. Some cuts in the edges of the rubber allowed the filter to be re-shaped into a rectangle. Some 90 degree clips on the top and bottom plates help it to hold the shape and VIOLA! A "Weber" look air filter.
Worked quite well and with the rear deck closed everybody thought it had Webers.
Rick
