Hi everyone. Sorry I've been quite busy and Lynn was nice enough to let me know there was an aero discussion going on.
Last winter I attached linear potentiometers to each corner of my suspension. Using a controlled power source and my LM-1 lambda gauge I gathered ride height data from zero to 160 mph and kept that speed for a half mile.
Yes that nasty Beast got to 160 inside a half mile with half throttle in first, half throttle through half of second then WOT the rest of the gears.
Maxton AFB is very bumpy. I did a lot of averaging to get the median data. With my series 1 splitter and side sill extensions I got about 300 lbs down force in the front and 150 lift still at the rear. I've redone the side sills and affixed a small tab (ala 2005 GT) and I'm headed for the wind tunnel.
If I have rid the car of lift I have the Series 3 stuff in mind to remove drag. It's been a lot of fun. You need to pick up the video of my 162 mph run and take a close look at the rear part of the nostril section. THAT needs to stop.
So I'm really close to being able to test the car's real top speed. But I seemed to have run out of the gobs of cash it took to get this far so I've come up with a side venture. (Obvious commercial plug here)
Six Minute Tutor - Home Anyone making quality videos you think might fetch a price, I host them for free. Go live at end of March.
Cough, cough. Did I say that?
So all I'm waiting on now is a single radiator exhaust opening nose piece and I'm off for some wind tunnel testing.
The splitter works perfectly but there is still some lift at the rear. And that's the MkI ERA.
One major caveat here is each manufacturer's GT40 nose is different so no one splitter will work for all cars. I have molds for the ERA and for the tube frame CAV which is also..... brain fade. Anyway gotta run. Filming Tae Kwon Do forms tonight. Hiiii Yaaaaa!
