| Re: Brett's RS GTD Hi Brett
On my car I welded a 25 x 5mm strip across the footwell from where the outer rail starts tapering forward, across to the centre rail. I then welded in two further rails of the same material running forward to the crossmember. These were pre drilled and threaded with a series of holes to mount the peddle box to. You could do the same but instead of welding to the chassis, weld a strip upright on the ends to take two bolt on each through the sides of the chassis rails, similar to the way the engine cradle mounts.
Brian.
__________________ GTD, 289, ZF. |
