Old 03-10-07, 04:18 PM   #4 (permalink)
Russ Noble's Avatar
Russ Noble
New Zealand
GT40: Building scratc
Re: Porsche 930 overhaul.
Originally Posted by RamboLambo
Hi Paul. In the interests of nature and science, can you measure the diameter of the input and output shafts when you have the box to peices? Also the distance between the bearing centres eg: input shaft front bearing to input shaft rear bearing. Oh and also the largest diameter of the pinion gear (the part closest to the bearing).
Also the 1st/2nd gear tooth widths!
