Old 03-19-07, 06:59 PM   #16 (permalink)
ross nicol's Avatar
ross nicol
Re: CAV - Getting The Horsepower To The Ground - Part VII
The support in front and behind the gear stick is the solution to flexing of the gearshift rod. Quite a lot of pressure from the ratio of the stick is applied to the rod which I found was ok when pulling the rod but would flex it, when it was being pushed. I could feel the flexing when changing gear and totally fixed it with the new shifter. The reason I made the alloy blocks so large was to make absolutely sure the flex would be eliminated.I like Jim's design but I think a heavy hand could flex the rose joints IMHO.
Bill there is a male rose joint underneath the rear block and bolted to the block.Does that make sense? I'll take another photo for you if it doesn't.
Ross
RF #025 currently racing
ZF,Motec injection
Lotus Europa S2
De Tomaso Pantera
ross nicol is offline   Reply With Quote
