| Re: SPF MKII Ownership Two more items I forgot to mention:
There are no door stops on the car and you can open the door too far and damage the paint. Be careful.
The door latches on the outside have little space between them and the fiberglass molded aroud them. They scrape the paint inside the recess. Not much can be done about this except maybe placing some clear protective tape in there. The minor paint damage is not visible unless you pull the door latch out and look into the recess.
