Old 03-23-07, 11:20 AM   #43 (permalink)
Sandy's Avatar
Sandy
Gulf GT40
GT40: RCR GT40 Gulf
Re: Sandy's RCR40 Gulf Chassis #11
Gary -
6,000 Rpm, please, no risk of pumping a rod out the side of the block.
I have a bit of work to do before I can fire the motor. I have to start the wiring and plumbing and pull the trans to do the clutch before I can do the 'Bleach Burnout' and put that to urge to rest.
I had the car since 3/20 and have been in the garage 3 time, once to push it in and the other 2 to look and make motor sounds with my mouth, but no amount of time doing actual work. After some sleep this weekend I'm hopeful to actually doing something.
I did order a flame arrestor for the carb, talked to Classic instruments for a new 10k rpm tach with appropriate redline, oil temp gauge, and have a boat load of wire stuff from waytek wire showing up very soon. I think the dash will be the first thing to be done then I can sit and make motor sounds _and_ push buttons...
I still owe more pic's, likely this weekend.
Sandy
Sandy is offline   Reply With Quote
