Slam Catches for rear clip
Mark Charlton
Does anybody sell these as a retrofit for older cars? MY GTD uses Dzus fasteners and I would like to improve on them.
I would like either a set of slam catches (like on the attached CAV—both the frame and clip portions), or possibly the protruding hood-pin style (less desirable to me).
I have considered also adding a plunger-type pin (Bill Bayard's car) as added security, considering the posts I've read on slam catch failures.
Thanks,
JimmyMac
What's wrong with the originals ?
You could also fit a couple of original Protex fasteners to be sure.
Mark Charlton
Simon, I did consider those but find them a bit too visually dominant.
James, perhaps you could direct me to a local GT40 replacement parts depot? My local Ford dealer just looked at me funny when I asked for those. :) Yes, those are what I am looking for, although I will obviously accept far less.
Thanks guys. I still need help.
JimmyMac
Mark,
I understand that the early Austin Mini slam catches are very close to the excellent ERA solution (other's opinion) but those in the photo are from the Ford parts bin so a bit of detective work is necessary.
I will give it a go.
Mark Charlton
Thanks James, much appreciated.
I must say that one of the aspects of these cars that I enjoy is the searching and innovating that needs to be done to solve problems and improve them. It's not just a matter (thankfully) of throwing money and having everything work out.
Mark Charlton
James, you are awesome! Thanks for both of those posts. Since I'm not craving exactness as much, the later post looks like what I will go with. The brackets should be easy enough to fab up.
Again, many thanks! :)
