| Help on throttle cable hookup. As you can see in the attached picture, the end of my throttle cable has a 90 dagree ferrell on it. I need to connect this to the throttle on the manifold as shown in the second picture. The problem is that I cannot find anything that connects to the ferrell and would allow me to conect to the throttle arm.
I checked with Lokar and was told about a universal part that I could use but it would require cutting the ferrell off of the cable and inserting the cable end into this part were it would be held with a set screw. My concern is the set screw slipping and the cable being pulled out at a bad time.
Any suggestions?
Peter
__________________ Roaring Forties #80
306CUI, SBF,8 Stack Injection
Motec M800 ECU
Audi 5N with 3.22 Ring and pinion
17 inch Vintage Wheels
Florida Plate # GT40 MK1 |
