| Re: GT40 Engine Build Mirage Chassis Thanks Guys
My engine is running 10.5:1 compression (sorry omitted that info).... so it looks like about 30 degrees max advance should be used, which means that I would need 4 degrees initial advance using the 13 degree centrifuge slot.
Its a standard 2 bolt 289 block, original iron heads and a 'mild' cam. Im looking for 300 HP which will be enough for me.....
What effect will the initial advance have on tickover, I want the engine to rev at about 800 at idle or is this more a function of the cam profile?
Regards Andy
__________________ replica mono chassis
original rear clip
1966 289
48IDA's
This month its going to be red
'This car you have to be measured for...' |
