Old 04-22-07, 03:48 AM   #14 (permalink)
brettmcc's Avatar
brettmcc
GT40: RSGTD
Re: Kennedy Engineering
Ron,
You're right about the 01X. I knew I was taking a risk when I did it, as thier's was for a 5000 and mine was a 01X. However, as I had already one of their plates and had mated my box to it and it fitted (bar one hole misalignment by a few mm) I decided to take the chance.
Yesterday after finishing the lights I decided to slip the bell house casing on anyway just to see. It fits. I turned the crank and the flywheel/pressure plate does not interfere with anything inside. Now being a little bit more rational this morning, I will wait until the full box is back and see if I can play around with it. In the meantime I am going to to see if I can get a drive plate for my input shaft, as Kennedy's plate is only a Sach's unit anyway.
I guess what I am most dissappointed by is the complate lack of listening to the customer. I could not have spelled it out more clearly in my set of requirements. At least the situation may be recoverable in one of three ways:
1/ get an 016 and be the test mule of Stu's gearset
2/ wait for the box to come back and see the fitment and if it works get a new driveplate and pilot bearing (I didn't like thier roller bearing anyway)
3/ speak to Fran and Chris about their adaptor
Brett
Roy Smart GTD Chassis with complete Southern GT Rear modification
Chris Melia Body
Mexican block
Audi 01X that just needs the gear change sorting
brettmcc is offline   Reply With Quote
