Old 04-23-07, 12:54 PM   #26 (permalink)
Sandy's Avatar
Sandy
Gulf GT40
GT40: RCR GT40 Gulf
Re: 4bbL vs weber or stack for max hp from 302
John -
Likely the carb is not set up right. The Edelbrock carbs are the old Carter AFB's which are a bit simple of a carb and IMHO harder to get working then a Holley. The Size of the carb is also not likely your problem, and depends on your engine capabilities, a 600cfm-750cfm holley might be fine, but a few things will determine that, cam/rpm potential, cubic inches, etc.
Sandy
Sandy is offline   Reply With Quote
