| Jeff's RCR40 Well here is my new build thread. The wife is 5"2" and the pedals wouldn't work for her where I wanted them. I have a friend with a vertical mill and he can use it. After much debate he copied a shelf I had in the garage. The rod in the rear will be cut out after it is mounted.
I got the fans mounted. I ground down a 1/4" bolt head and slid it into the mounting tab on the top of the fan. I bent aluminum flat stock to fit over the radiator and then drilled one hole in it to hold it on. The bottom is fastened with the mounts that came with the fan and 3/16" rivits.
