| Re: Alternator 3? wire connections Lee
The big terminal is the high current feed to the battery.I would fit a high current fuse near the battery (60A) or higher in this lead. In this day and age it is surely internally regulated and one of the spade terminals will be power from ignition switch and the other most likely dash charge light.Doesn't do any harm if you put 12v on any of these terminals to check what's what and you'll work out the terminals if you have an ameter or voltmeter. Hope this helps
Ross
__________________ RF #025 currently racing
ZF,Motec injection
Lotus Europa S2
De Tomaso Pantera |
