Old 05-20-07, 12:12 PM   #3 (permalink)
Gary Kadrmas's Avatar
Gary Kadrmas
Silver Supporter
GT40: Not yet, but so
Rep Power: 12 Gary Kadrmas has much to be proud ofGary Kadrmas has much to be proud of
Re: New to all of this
JB,
Welcome aboard!
Owning your SPF Mk III should be a good benchmark for guiding you in the direction of finding the right GT40 for you. The fact that you became a member of gt40s.com indicates you are the type of guy that does his homework first. Good start! Your SPF Cobra suggests you based your purchase on certain requirements. I think you will find that suppliers of GT40s are all across the board, just as Cobra replica companies. As you are probably aware, SPF has a very fine GT40 available in turn-key minus form. Depending on how big your piggy bank is, your technical and mechanical skill level, and how you intend to use the GT40, will most likely be factors in which 40 is right for you.
I suggest you do a little surfing on this web site. The answer to your question can be found in the many subsections on this web site.
Good luck!
Gary Kadrmas
___________________
Owner of CSX-2075 for over 30 years, and wanting a GT40 for over 20 years
Gary Kadrmas is offline   Reply With Quote
