| Re: Cooling System - Excess Pressure Pat,
1.. The hose fitting should already be there on your water pump directly below the one that the bypass is fitted to. It may have a rubber cap over it or the pump may have a blanking plug screwed into the threaded hole. Remove that cap/plug & fit the appropriate hose stem or fitting if reqd to attach the hose from the bottom of the header tank. Good Luck, I 've gotta go put some fence posts in to keep the cattle out of the garden!
Jac Mac |
