Old 05-24-07, 09:12 AM   #4 (permalink)
Julian West's Avatar
Julian West
7 Tenths
GT40: GTD
Rep Power: 14 Julian West has a spectacular aura about
Re: chassis modifications
Hi Steve,
interesting questions! With regard to raising the steering rack, there is an interesting discussion on bump steer here bump steer
With regard to changing the rear suspension geo (80mm sounds like alot!) check out GTD rear suspention mod
Re bracing the roll 'hoop' I fabricated a full cage out of 50mm CDS & took the roll bar rear stays to the top damper mounts. this was *alot* of work but will increase the safety as well as adding some stiffness to the chassis.
I've attatched a picture of the mods I made to my chassis. If I were to do it again, i would leave a bit more room around the rear of the gearbox.
Hope this helps.
Name:	chassis painting 006.jpg
Julian West is offline   Reply With Quote
